- Dec 21, 2013
Good news, guys! I sprayed some WD-40 all around it and turned the gear with a pair of pliers - and the dial moved with it! Slowly but surely, it loosened up. Kept twisting it around, and got it to where I can turn it with my fingers. Engaged it in the lead screw and turned the lathe on... success! It don't feed the carriage, and it does feed the dial.
Problem solved! Thanks so much to everyone who helped out, I really appreciate it.
Just to make sure - how easy should the dial be able to spin by hand? Real easy, or have some resistance?
