    Dismiss Notice
Craftex Cx-601 Mill / Drill Machine
Discussion in 'HARBOR FREIGHT, CENTRAL MACHINERY & BUSY BEE' started by owdlvr, Jan 17, 2016.
  1. owdlvr
    owdlvr Canada Iron Registered Member
    7
    3
    City:
    Squamish
    State:
    British Columbia
    -Return to Top-
    After quite a bit of research, I picked up a Craftex CX-601 Mill/Drill machine this week. The research was actually pretty tough, as there is little online written about the machine. I thought, therefore, it might be helpful to future users to have a little written up about the machine.
    I'm presuming if you're looking at one of these, you're going to compare specs, and you’ll find that very similar machines are offered by Grizzly, Precision-Matthews and others . You’ll find the castings and controls are almost identical between machines, but the specs can vary wildly. Presumably all the castings are made in the same factory? It’s quite probable all the machines are made in the same factory, but the final specs are ordered by each customer and will vary from brand to brand. Work out what you want in a Mill / Drill, determine the specs you most require, and narrow your search accordingly.
    I suppose I should note two key things: One, the Cx-601 is a Mill/Drill machine…not a ‘proper’ milling machine. I didn’t buy this expecting I could hog a ¼” of steel in one pass. Instead, I realize the smaller machine with no heavy base has limitations. My shop space has limitations as well, and quite frankly a mid-weight mill/drill is better than no mill! Secondly, it’s a machine made in China. I bought it knowing that China CAN make very good products, but they can also have issues. I inspected the floor model quite carefully, and looked for posts online with Craftex problems to try and work out if I thought it was generally a ‘quality’ brand. Ultimately I chose to buy one, so in my case I thought the price, quality and features lined up to my satisfaction.
    On to the Mill!
    I suppose the first thing to consider is how you’ll unload it. I used an engine hoist and a specialized vehicle tie-down strap, but even with my 2wd truck it was a challenge. The mill weighs roughly 600lbs, so with the engine hoist extended all the way (1/2 Ton setting) there was plenty of leeway. With my truck, however, and the hoist lifted all the way up, it just cleared the bed to come out. This was with the head roughly halfway in the Z-Travel, so I could have dropped the head for more clearance. You’d need to in a lifted or 4wd truck. I managed to get it into my shop, and the stand almost bolted on before a buddy showed up to help. Two makes the stand easier, and you will definitely need two people to slide it into final position.
    My mill was built in January of 2015, and I purchased it in January 2016. The date is stamped on the front cover, lower right. Unlike the reports from Grizzly owners, my stand was in perfect condition right out of the box. Its well built, and relatively sturdy, but I have to say the stand sucks. If you’re over 5 foot 5 inches, save your money. I’m 6’3, and the mill table is painfully low, I’ll be building an additional stand to lift this thing up. Regardless of the stand you use, you want it to be as heavy as possible. Don’t use the stand for storage, use it for storing dead weight…and lots of it. Your mill will perform better.
    The Craftex CX-601 ships with the following items (and my comments):
    1. Manual – It’s not terrible, but the Grizzly manuals are better. Go and download a Grizzly manual for a similar machine and use it for unloading tips, setup tips and break in.
    2. Tools – They’re terrible. Mine shipped with a 25mm wrench (nothing on the mill is 25mm), two double-ended open wrenches (chrome flaking off) and screwdrivers, allen keys and some other stuff I didn’t even open.
    3. Touch up paint – leaked into the bag, rock hard.
    4. Vice hold-down bolts – actually useful.
    5. And of course the Mill/Drill unit.
    My mill arrived with the following issues:
    1) Electrical cord fallen out of the grommet. Simple repair, required taking off the back of the electrical box and re-assembling the threaded grommet.
    2) Obviously poor bondo-repair job of casting flaw in table. The repair is laughable, but the T-Slot still works so I really could care less.
    3) Oddly smooth-stiff-smooth-stiff action on both the X and Y movements. I thought at first perhaps the travel screws were bent, but upon closer inspection found that paint drips hadn’t been cleaned off the bottom of the dovetails for both the table and saddle. A razor blade and some light effort brought smooth travel to all directions (no photos).
    After cleaning all of the shipping grease off the mill, I lubricated the various bits of the mill and waxed the table. I then set the stops for the X-Travel, trammed the head and setup my vice so it was square. After mucking around with various methods found online, and getting quite frustrated, I finally figured out a quick(er) way to tram the head on the CX-601. The fine adjustment for the angle on the head isn’t done via mallet taps (like on some mills), but rather via the 5mm allen key on the right side of the head near the top. The key was to tilt the head slightly clockwise, and then tram using the standard test-indicator method. BUT if you over-adjust past center, stop trying and move the head back clockwise past zero. Took me less than 1min to get it dialed in perfect once I had figured it out.
    I didn’t write it down, but there was less than .001 change in height between the extreme left and extreme right of my table. No measurable change fore and aft. I measured the spindle runout, but didn’t keep note of it because it was basically nil. Essentially it would appear I got a quality machine, with a bit of a bondo job in the one t-slot.
    The gearbox in the CX-601 uses the same plastic gear setup you’ll find in a number of mills, and the one you’ve probably found threads saying there are “lots of threads” talking about them breaking/stripping…but I didn’t find those actual threads. Regardless, there are four gears in the machine. A brass pinion gear on the motor, a plastic counter gear under the motor mount, a plastic gear which has a high and low gear on it and finally a metal gear on the column which has a corresponding high and low gear. I am not sure which gear is the one that strips out should you crash the machine, but I suspect it’s probably the counter gear. The machine has no provision for adjusting the gear lash on any of the gears, but I was able to adjust the gear lash on the motor pinion to counter gear by using the slight play in the six motor mount bolts. I essentially loosened them a touch, moved the motor as tight to the gear as I could, and then (with the machine running) tapped the motor mount back until it sounded right. You need some experience with gear noise to be able to do this with some confidence.
    Speed is measured using a hall-effect sensor mounted to the top of the spindle. Max speed on my machine is building through break-in, and should hit the specs.
    The switchover to fine control on the Z-Axis leaves a lot to be desired. Basically you tighten the the down feed handle onto this brass cone which engages the fine feed knob up front. It slips, a lot, despite having the grease cleaned out. The digital readout on the front is very necessary, as the mechanism slips too much to make the traditional knob markings useable.
    I’ve you’ve read up on these machines you may have found a post or two claiming that the scale on the handles doesn’t match the feed, and/or that it’s a really weird amount. On my machine the scale is .0025”, and travel on the table matches exactly (as measured with a dial indicator). One full turn of the handle gives 0.125” movement, so the math is easy to do in ones head. I should note that the scaled collars on four of the five handles were so tight I could not turn them to zero the dial. I’ve popped one off and it was an easy fix (spring wasn’t in correctly), so I anticipate the others will be just as simple.
    I bought a generic “Kurt-Style” 5” vice for the mill, despite the salesman suggesting a 4” was probably the better size for the mill. I disagree, the 5” is pretty much perfect, though I do lose the final ¼” of table movement in on the Y axis. Not a big deal, I’ll be mounting DRO scales back there eventually anyways…so I’m losing that travel regardless. As a side note, this Vice (bought from Busy Bee Tools as well) is pretty terrible. This is why we hate Chinese made goods. The moving jaw is shimmed with folded paper to make it square (WTH?!) and the tops of the jaws are not parallel. I should have inspected it much closer before cleaning it.
    I did follow the salesman’s recommendation on the 6” rotary table vs going with an 8”. Again, I disagree with him and think the 8” would have been a fine size. I was going to replace it, until I realized that I was going to want to create a pallet for the top of the table, so I could simply make my pallet 8”. (I'm checking the pin I made for centring the table.)
    For those not familiar with the term, a pallet is basically a fixturing surface with options for bolting items to the table, or locating them with pins. The pallet can be sacrificial, ie you can cut into it with tools if needed, so that you don’t ruin your table base.
    Machine cuts quite nice both conventionally and climb cutting with various sized end mills. I did surface a 10x12” piece of aluminum using a 3” endmill with 6 carbide tips on it. Cuts of .005 were very smooth, cuts of .010 were at the limits of the machine. I want mine to last forever, so I was happy taking smaller passes.
    There are a two things on the machine (so far) not mentioned in the manual. First off is the oil window in the head. There is no oil in the head, only grease, so I’m thinking the casting must be used on machines of a different type and the window is simply ‘there’. With the grease sprayed on it, you’re definitely not going to be seeing anything inside!
    The second one is this spring loaded pin in the back. It's visible in the photo just a touch to the right of dead centre. No mention of it in the manual, and I haven’t worked out it’s purpose yet. I suspect it may be a safety pin to keep the head from rotating too far when you loosen in, but I don’t know yet. Once I trammed my head perfectly, I wasn’t going to change it!
    Happy to add more or answer questions / queries on this machine. It was a bit frustrating when I was doing the research, not finding very much info out there on it.
    -Dave
  2. FOMOGO
    FOMOGO United States Active User H-M Supporter-Premium
    1,119
    113
    Colorado
    City:
    Steamboat Springs
    State:
    Colorado
    -Return to Top-
    Nice write-up, what tool holding does it use? Mike
  3. owdlvr
    7
    3
    City:
    Squamish
    State:
    British Columbia
    -Return to Top-
    R8 Spindle.
    Specifications (from the Busy Bee Website):
    Motor: 1.5HP , 110-V, Single Phase
    Drilling Capacity: 32mm (1.25 )
    End Mill Capacity: 20mm (0.78 )
    Face Mill Capacity: 76mm (3 )
    Spindle Taper: R8
    Spindle Stroke: 70mm (2.7 )
    Head Tilt: 45-degree to the Right & 45-degree to the Left
    Number of Spindle Speeds: Variable
    Range of Spindle Speeds: 50 2250 RPM
    Working Surface of Table: 840mm x 210mm (33 x 8.2 )
    Table Longitudinal Travel: 425mm (16.7 )
    Table Cross Travel: 220mm (8.6 )
    Number of T-Slots: 3
    T-Slot Size: 10mm (0.39 ) WRONG - Well, mine shipped with 3/8" t-slots at least.
    Overall Dimensions: 850mm x 890mm x 1120mm (33.4 x 35 x 44 )
    Net Weight (approx): 240 Kg, 529 lbs
    Shipping Weight (approx): 280 Kg, 617 lbs
    Warranty 3-Years
  4. brav65
    brav65 Active User Active Member
    385
    63
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    Excellent write I am sure many fellow Canadians will find this very helpful.
  5. MachGeek
    MachGeek United States H-M Supporter - Premium Content H-M Supporter-Premium
    4
    3
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    Great write up - thanks for the details.
  6. ironhead785
    ironhead785 Canada Swarf Registered Member
    0
    1
    City:
    woodville
    State:
    Ontario
    -Return to Top-
    thanks I still not sure which one 601 or 602 thinking going cx-602 or 603
  7. ahnatiw
    ahnatiw Canada Iron Registered Member
    8
    3
    City:
    Ottawa
    State:
    Ontario
    -Return to Top-
    I bought the CX-601 about a month ago. Used it a bit so far, works well. When I was cleaning and tightening the various fasteners, the T-bolt holding the column to the head failed...right at the T to shaft interface. After taking the z-axis apart I learned a few things.
    Inside the column is a piston to counter balance the mill head assembly, nice touch.
    The "spring loaded pin at the back" (photo in the original post), is an index pin and has a matching set of holes in the z-axis saddle for various angles (did not check, but probably 30 deg, 45 deg, etc.).
    I replaced the junk T-bolt with a grade 8 bolt...pull the casting apart before it yields.
    I also bought the Tormach R8 collet and some tool holders.
    Next step is to build an air cylinder power drawbar.
    Stay safe and happy machining!
    Al
    bmw rider likes this.
  8. ccarrigan
    ccarrigan Canada Iron Registered Member
    0
    1
    City:
    dawson creek
    State:
    British Columbia
    -Return to Top-
    Hello, I was wondering if you ended up building a stand and if you did, how much of a lift did you give it? I have the same problem on the same machine and stand and was thinking a 12" lift might be right?
    Thanks
    Christopher
  9. ahnatiw
    8
    3
    City:
    Ottawa
    State:
    Ontario
    -Return to Top-
    I built a wooden bench fasten to a 2x4 wall. Top of the bench is about 28" high. I used an engine hoist to lift them onto the bench.
    Did I answer your question?
    Al
  10. Hidyn
    Hidyn Canada Active Member Active Member
    18
    8
    City:
    Calgary
    State:
    Alberta
    -Return to Top-
    Thanks for the quality write up! It's good to know there's equipment that can be purchased any day of the week that isn't -that- bad and can be fine tuned at a reasonable price!
  11. bmw rider
    bmw rider Canada Active User Active Member
    50
    28
    City:
    Calgary
    State:
    Alberta
    -Return to Top-
    I've had my CX601 for nearly four years and just this week discovered a problem.
    I'm not sure how this happened, but can say that I have never had a crash or any other event that might have caused this. I pulled the shaft out right after I noticed it and went over to Busy Bee to see about a replacement. Curiously, they had two of them in their warehouse and I should have it in about two weeks for just $119.
Share This Page
