- Oct 4, 2011
- 727
I have several of questions about the compound slide on my lathe.
The first is a general question, not dependent on lathe type. My compound is graduated in .001". Does anyone know what angle to set the compound so that each .001" moves the tool .0001" in the direction of the cross slide? I know I saw this written up some where but now I can't find it.
The second 2 questions deals mainly with the wholesale tool lathe WT 13" x 40" Gap Bed Geared Head Lathe or any lathe with the same layout on the compound.
When I first got my lathe I used a dial indicator to check to see if the cross slide dial was accurate. It was not. After some reading and checking around I found it was because they used a metric screw that was close to the right pitch but not exact. So I switched the screw out for a standard 10tip and now it reads spot on. Has anyone done this to the compound rest screw? If so what was your procedure?
Second question has anyone mounted a digital caliper to their compound as a cheap DRO? If so how and what position.
Thanks,
Jeff
Thanks,
Jeff
