My 12" Enco table has Tee slots parallel to the vertical base.
The 6" Tormach, which appears to be a Phase II clone, is at 20* when the slots are parallel to the vertical base. The degree scale in engraved into the table so it can't be adjusted relative to the Tee slots. Jumping a tooth on the worm will not change it.
Looking at the table construction, it appears that there was a design failure when designing the casting as there is a rib which would possibly interfere with milling the flat for the index plate so they just shifted the flat by 20*. That leaves moving the index mark if you want to shift where 0* lines up.
As I looked at mine, I think that I could mill a second flat and drill and tap the hole for the index plate mounting screw. It is not important to me since mine is motorized and has a DRO.
When using the Enco table, I would make up a table of the angles that I needed to machine at since it is difficult to line up a workpiece precisely parallel to the RT ways. e.g., if I were machining something with five-fold symmetry, my angles would be multiples of 72*. If my offset is 4* 30', I would add that to the desired angle to get the machining positions so 72* becomes 76*30', etc.
I find that the table index mark doesn't have to be precise because on a 90:1 table, the dial on the worm repeats every 4* ant the dial is what I use to set my angle. The table index mark just gets me in the ballpark so ,in the above example, as long as the index is more than 75* and less than 78*, I'm good. I do have to pay attention to where on the dial I am, however.
