- Oct 31, 2015
- 469
I would like some opinions. I have a 10"Logan bench lathe. I am currently making a set of legs similar to the ones Logan sold as an accessory and will be mounting them soon, along with a Logan chip pan that I got off of EBay. My question is, should I add some sort of drain to the pan before I mount it (while it would be easy to do )? I was thinking along the lines of drilling a hole and welding in a pipe nipple or union. I do not currently use coolant, only cutting oil, so I'm not familiar with the plumbing for the various coolant systems.
Is this a good idea? If so, where should I put the drain? How big should it be?
Thanks,
T. J.
Thanks,
T. J.
