- Oct 11, 2016
- 3,868
@Gaffer I've done 2 VFD conversions for lathes (for me) and advised on many more.
Short answer: Yes you can, and you might love it.
The Baldor motor is just under 1 HP real power. Because of its use, it is intended for 'soft start' which a VFD provides. Because of the weight of the chuck and drive train I *usually* advise going to the next higher increment in horsepower to minimize strain on the motor when starting up the chuck/drive train.
This motor is *intended* to start under load, but dropping down to 1HP will be noticeable. Since your motor/VFD is likely to cost you around 100$, your risk is minimal. You will gain a lot of advantages using a VFD on a lathe, so give it a try.
I would first wire the new motor/VFD completely separate from the lathe, install it, and then see if it meets expectations. I did a LOT of work on a 1/2 HP South Bend lathe in my time so if you are OK going slow, then you will love it.
