- Jun 12, 2014
- 4,818
The PM-833TV is a 2 Hp motor and they indicate that it can run off of a 230VAC 20A single phase circuit. Pn the PM-935 with a 3Hp motor on a VFD you should be using a minimum of a 30A circuit, this would require 10AWG wiring. The reason why PM/QMT may suggest 20A/12AWG might be for 3 phase input power, I did not see any indication the PM-935 manual as to fusing or wire gauge for this mill, and running it off of a VFD is a completely different set of electrical requirements. My understanding of the NEC wiring requirements for VFD's is that the input wire current rating needs to be at least 125% of the rated VFD input, and is independent of what the output current is set to. The input current rating of the WJ200-022SF is 22A single phase, so the wiring would need to support 27.5A, thus the 10AWG on a 30A breaker.
