- Dec 21, 2013
- 186
Hey guys. I know this is probably a recurring question around the web, but I actually can't find a lot on HM.
I plan on making an extension to my current work... shed. It currently only has a wooden floor, with 2x4 joists on 24" centers and two layers of OSB sheet. Fine for my little 618 lathe, but I don't have the room nor faith in the floor to have any more.
I am looking at purchasing a mill no bigger than a PM-45/932-sized mill-drill, which apparently has a weight of 1100 pounds from the PM site, more likely a PM25 which is only 350 pounds.
I would also like to eventually have a larger lathe alongside the Atlas, something like a PM 10x30 or 11x27, which slightly exceeds 400 pounds.
The extension I would like to build will be 12 foot square, 12 x 12.
Pretty sure I need a concrete floor for machinery of that size along with the Atlas and other storage furniture and such. The question is thickness and specifics of the concrete.
Would a 4" thick slab work for this? I will not purchase larger machinery than mentioned, as for anything larger, I would need to build a better, standalone shop anyway.
Thanks fellers.
Thanks fellers.
