- Jun 12, 2014
- 4,826
It is not unusual to see the same compressor pump used with different Hp motors, so there is a range which possible by changing the motor pulley to run the compressor slower. There can be fairly high starting current with out a unloader, so there are limitations and you need a substantial motor rated for compressor use. At least in the US, it is not uncommon to run up to a 5Hp compressor off of 240VAC single phase. I had a two stage Curtis belt drive with an E-57 pump, this pump would accommodate up to 7.5 Hp. Two stage compressors usually go to 175 PSI tank pressures, so affords you a longer running time before the motor kicks in. The CFM output is usually rated at different PSI, but ultimately is limited to the pump size and the motor Hp with continuous use like with a media blaster cabinet. This usually requires something in the 12-18 CFM range for a smaller cabinet. Single stage piston pumps is usually used in lower CFM units. A good cast iron pump or metal sleeved pump goes a long way toward longevity and helps quiet things down a bit. My biggest issue with most compressors (in the shop) is the noise, better compressors run slower (4 pole) motors and pumps which tends to reduce the noise. Pump design wise, I do not think it matters as to the configuration, bigger pumps tend to be in a V configuration. This also may afford slightly better cooling, not sure on vibration. Most of the better pumps of some form of air to air cooler between and/or after the 2nd stage. Older pumps in most cases can be refurbished and perform well, older compressor tanks, I would be worried.
