I've always run my air lines in black pipe, with a piece of hyd hose to isolate the compressor from the system. The new shop is going to be a combination of black pipe and copper, because that's what I have around. 1 1/4" black for the main runs and polished and clear coated 3/4 and 1/2" copper for the trunk lines, and drops. Pulled several hundred feet of L copper out of a building I was converting from commercial to residential over most of last summer and fall. Seemed a waste not to put it back to work, and hey, it will be shiny! When finished, I will have the combined output of three 80 gal., 5hp, two stage compressors available for heavy duty sand blasting of car frames and such, but 90 percent of the time will just be running one. I think the Rapid air systems are a good, and easy way to go, but I guess I just like the retro look. Here on the island I ran around 100' of 1/2" K-copper for my air, which was nice because you could bend it to go where ever you wanted, which really cuts down on the number of fittings you have to sweat. I think one of the best things you can do when designing your air system is to place your compressor outside of your workspace so you don't have to listen to it. If it has to be inside, a large inlet filter/silencer can help cut the noise substantially. Mike
