- Jun 8, 2016
- 603
the only bar that was present when I took mine apart with steel. I bought new steel ball bearings of the same size and replaced all three with new ones. I had considered actually undercutting the dial and using a sheet of Teflon type material to provide the friction without spring pressure whatsoever. However as a newbie, I thought that might possibly be outside my scope of ability right now. in the future, if it looks like it may be an issue, I believe I would undercut and use a slightly thicker piece of Teflon sheet as a friction material after removing the springs and balls completely.
