- Dec 19, 2014
- 167
You will get some mess. I just stuck a rag below the plug before pulling it. Before you remove the plug, have every thing ready and do a hot swap between the plug and pipe. If you fumble with the pipe just put your finger over the hole and try again.
One thing the picture doesn't show is I had a end cap on the pipe. That way you don't have to worry about aligning the bucket up until the hot swap is done. Pipe sealant on the threads is not required. Lathe should take 2 1/2 - 3 gallons if I remember correctly. You can't purchase this oil buy the gallon. Only in 5 gallon pails or drums. I highly recommend you pull the top and clean it out. Mine had a lot of crap in it and a broken roll pin. I was able to find a replacement pin at Tractor Supply, in stock. It is a long pin. I think 1/4" x 2-1/4". Use a anaerobic gasket maker to reseal the top.
Colchester oil change
Broken roll pin. Pin was still working in gear but pieces were laying in sump bottom.
