- Oct 16, 2019
- 6,576
@rabler So far I have 3/4 of the cutting part... I still need to figure out the actual table part
I have a welding table with a 3/8" thick top.
My napkin-grade idea is to add a couple of square tubes under the top of the table, like hitch receivers.
Then I'll make a frame that will hold a tray and slats. The frame will have arms that slide into the receivers.
Thinking I will add a drain to the table.
Hoping this will let me pull the table off, and store it away. Recognizing that it will be a messy process.
