- Oct 16, 2019
- 6,576
It's a blowback start torch so as soon as I pull the trigger/activate the torch it fires, even if it's inches away from the stock.Excellent project.
The cutter is starting and running OK without an active Z axis height control, yes?
There seems to be some error between when the cutter is moving away from the camera vs toward camera. I noticed what looks like (nearest the camera) a flat (cord) on the round hole and the two short segments of the square don't converge. Are those intended or mechanical backlash or software tuning? My question is, if those observances aren't intended, where do you expect to implement the fix?
I'm not sure what happened on that square as I re-ran the file and it cut just fine. I have a hunch something got hung up
@extropic I figured out the problem. The torch cable moved the sheet slightly as the X-axis moved toward the camera.
Starts at :07s in the video. You can see the edge of the sheet move about an 1/8"+.
