- Feb 8, 2014
- 11,144
It looks like the CNC4PC C11 board will work fine for the interface. The only other things you need are a power supply and stepper driver boards. It looks like the power supply is available in the Denford cabinet, but check for compatible voltages. I'm not sure how you would access the original stepper drive, so a separate board will probably be required to drive the motor(s)
