- Jan 7, 2016
- 3,291
I have a Sharp LMV mill with a Southwest Industries A.G.E. 2-axis CNC system on it. It works great a manual mill and with conversational programming, but the thing is nearly worthless when it comes to loading programs into it due to the fact that it still uses floppy disks. Yes, I have tried to install a USB reader into the floppy port, but I could not get mine to work for some reason. As someone else mentioned, if you find a good mill with an old A.G.E. system on it, plan on upgrading. Once I get time, I plan to install a 3rd axis on mine with a Centroid control.
Programming g-code manually, in my opinion, is a slog. Yes, it can be done, and I have done it, but no thanks. Keep in mind that conversational programming is different than g-coding.
Also, be aware that if you buy a current model (used) of an industrial machine, such as a ProtoTrak, any parts that you may need will come at commercial prices. Just for giggles, I asked how much it would be to upgrade my monochrome screen to a color screen... $1500 bucks. And, that is just the screen.
Many folks have converted knee and bed mills to CNC, utilizing high-quality parts for far less than buying prebuilt commercial models. Yes, it will be a learning curve and take time.
