Cnc Mill Conversion, The Electronics Package. Updated
Eddyde
Staff member
H-M Lifetime Diamond Member
Oct 13, 2014
6,666
Hi All,
I have been assembling the components to convert a Bridgeport sized mill to CNC. I am starting with the electronics as the mill is not yet delivered to my shop and said shop is in my second home, 100 miles north of my primary residence. I carved out a niche in my home office to test the gear and get the bugs out of the system as much as possible before mounting servos to lead-screws. As this is my first foray into CNC the learning curve is quite steep but much fun :)
My criteria for the project:
1. 4 axis (will start with 3).
2. High accuracy, and no backlash worries. to that end I will be using linear encoders on the XYZ axis load. I started a previous thread on this subject, here.
3. Retain full manual operation.
4. 2D, 2.5D & 3D capability.
So far I have:
Galil DMC 2240 Motion Controller (4 axis).
4, Galil 12-80 Servo Amplifiers (Drivers).
3, Brushed DC 72v, 1125 oz. in. servo motors with rotary encoders.
1, 72v 20a power supply.
1, Dell Computer with keyboard, mouse & Windows XP.
1, Galil ICM-2900 Opto-Isolated Interconnect Module with 100 pin cable.
Spent almost $2k so far...
Things I had on hand:
20" LCD Monitor.
Gutted Mac G5 computer for the electronics package enclosure.
And a Gracious gift of control software by a fellow member.
What I have done so far:
Hooked up the Galil 2240 to the computer via ethernet, this was a real headache as the as the software the instruction manual said to use "Smart Terminal" couldn't assign an IP address to the controller. I wound up using the Galil Tools light (free) which worked like a charm.
I hooked up 1 servo and got it to turn :) Now I'm learning the commands and testing the servo, the encoder resolution is 8,192 counts per revolution and the max error I have gotten so far is only 5 counts!
Next up is getting the motion control software to interface with the controller...
One slick way to do that is to set up the IP address on the 2240 using the serial port for initial communications. I use a USB to serial adapter. The IP setup in SmartTerm is a bit of a PITA, and some times won't work correctly.
You do have to use the Ver 7 drivers with my software (which should have installed along with my software, if I did it right) , but I have worked out a way to use the latest GalilTools drivers but I need to play with it a bit more. I'll have a 4080 here later today to play with.
Yeah I was thinking about using a serial cable but didn't have one... I didn't try the Galil Tools at first because it doesn't officially support the 2240 but it seems to work just fine. Also, I have way more experience with Macs, the nuts and bolts of PC world is kind of new to me.
I will try to load you software today, fingers crossed :) And thanks again of sharing it!
