Cletus' PM-935TS-3PH Mill Log
@Cletus I see you are into 3D printing, along with some 3D helis. Very cool! We have very similar interests. I fly scale RC helis (and planes) along with utilizing my 3D printer for a TON of stuff around my shop. I was just looking at the Elegoo Jupiter printer. These SLA printers have become so affordable...
Indeed, 3D printing is so awesome, I use it for all sorts of stuff myself. I've been into model aircraft for as long as I can remember. Electric, petrol, nitro and turbine helis, and pretty much the same with the fixed wing aircraft except ducted fan jets in lieu of turbines. We have a pretty nice RC field about 400 acres, with a 360ft paved runway and covered pit AREA. Solar and wind power and a 6kw diesel gen for the fun-flys and eventsAbout 60 members in the club, but you know how it goes with clubs, only 10% of us do all the work.
I was at IRCHA at AMA HQ Indiana 2010 and 2011 with my Bergen Intrepid Turbine Heli, had a blast!
I’m and engineer, hence my complicated way of doing simple things :)
Here’s my revised Mist Coolant System, I really like how this is working out.
The diagram below speaks pretty much for itself. I am using a cheap Mist Generator from Amazon, common water filter as the coolant reservoir, combo air regulator and oiler and a 115VAC air solenoid valve with a remotely located switch.
Impossible to get “Cool Mist” or some such here in Trinidad and forget about trying to import it, so I have to resort to my own concoctions and the following is working well for me.
~30% Water Soluble cutting oil
~65% Distilled Water
~5% Isopropyl Alcohol
The mixture forms a light emulsion but over time it tends to separate with the heavier stuff settling at the bottom of the reservoir, hence the small aquarium air pump to keep things agitated/aerated and in suspension.
The rig is plugged into the switched outlets at the back of my mill.
The oil/water is a typical dilution albeit on the oil-rich side and the small quantity of alcohol creates a very low temperature when the mist leaves the nozzle.
The coconut oil in the oiler was left over from when I used coconut oil and pure alcohol in the reservoir for cutting non ferrous material. But fearing an explosion hazard, I have refined the system to this variant. I find this now works very well for both ferrous and non-ferrous cooling/lubrication when cutting.
View attachment 379087View attachment 379088
Hello Cletus. sr71xjet here from the Langmuir forum.....lol. Imagine that. Your mist cooling system. Did you make it or purchase it? I finally got my 1054 and it is pretty much set up. I am interested in setting up a cooling system as well. Ordered the powered draw bar which i should have done in the first place. LOL Thanks
I bought this one and used a water filter unit as the reservoir, an aquarium air pump as an agitator (to keep the emulsion in suspension) and an air regulator.
You have a cool setup. I get down there every once in awhile with my job. Ill have to look you up.
