For many years I used solvents and brushes to remove old grease and oil from parts. I hate to think about how many hours I spent sitting over a pan with solvent in it. About 25 years ago a friend put me onto using oven cleaner in aresol cans to degrease parts. It worked pretty well.
A few years back, I went to SAM's Club to buy the usual 3-pack of oven cleaner. I had some machines that were pretty greasy and I find that oven cleaner is a good way to clean it off. They didn't have the usual spray cans but they did have this stuff. I figured that it was some environmentally friendly stuff that wouldn't work very well, as is so often the case. It says "For professional use only, not for household use". I wasn't going to buy it because I figured naturally, that it was another product that would not work very well. It was under $8 for the 3-pack. I didn't want to have to go to another store so I decided to buy it. When I got home I hauled out a bunch of drill press parts. One part was a DP base that had dried grease and drill chips stuck all over the under side. Just the kind of mess I find very unpleasant to clean out. I sprayed about 8 parts with the cleaner. OK...It foamed up like the spray cans...that was good. I also noticed that it goes a little farther than the spray cans do. The sprayer is easier to pump than the little button on the spray can is to hold down for a long period of time.
I went into the house for about 10 minutes and then came back to check on it. WOW! The gunk was flowing all over the parts. I took the hose and washed the parts off. In the short time I had it on there, it liquified ALL of the grease and some of the paint. The parts came out clean as a whistle. I have to say I was very pleasantly surprised at the results. I find that sometimes it takes a re-application or some scraoing to remove large blobs. If I have a lot to clean, I apply the cleaner and rinse it with my small electric pressure washer. Does a great job.
I have done a few whole machines before starting to tear them down. I did a greasy logan a few years ago. After washing with water, I used raggs and compressed air to blow as much water off as I can. It was so much nicer to repair after the grease was removed from it. I do the application of the cleaner and the rinse, out in a spot on the lawn. It tends to burn the grass slightly but it recovers nicely in about a week. I suspect the burning is from the solvent application before the rinse.
It doesn't have any affect on the rust, of course, but it cleaned the parts faster and easier than ANYTHING I have ever used. I had to pass along this remarkable find. Like other oven and grill cleaners, I would not use it on pot metal or aluminum.
I hope you find this helpful.
Charlie
Charlie
