- Nov 25, 2015
- 8,314
If you can try a high pressure washer to loosen the stuff up. I assume you can get a wand in and move it around. Maybe even bend it at 45 (buy a new one for use later) so you can get to other areas.
As far as the stench. Once you clean it up, stick some charcoal in the sump. wrap each piece in wire so you can pull it out later. Leave it in for a few weeks once you dry the interior. Charcoal is a filter, it may soak up the smell.
