Clausing model 5907
Today rebuilt the master cylinder and installed it on the new top cover. Then installed the top cover after adding oil to the headstock. Then pulled the counter shaft assembly which was easy easy, 4 bolts and out it came. I removed the Reeves pully assembly to install it on my new shaft with a clutch and brake. Might get it in the mail this next week as he is shipping Monday afternoon. Pulling the Reeves drive off the shaft was simple. Removed 1 allen head set screw and then a Large screwdriver to start it moving and then taped with a dead blow hammer and it slid right off. I think i got lucky. Looks almost new. This lathe couldn't have been used bery much.20240414_162549.jpg20240414_182430.jpg
Still waiting parts from Clausing. I ordered a new Gits oiler as mine is leaking. And a oil level sight glass, and 1 clutch washer. And from across the pond from England a MDRO company very narrow 1um mag scale for the cross slide and a 5um for the carriage. They had the best deal so far for my touch dro. I'm guessing 2-3 weeks it will be finished.
Mike
My last bearing purchased from zero arrived today and it's installed. That's the Special radial bearing from Romania of all places.
And I received shipping confirmation for my 2 mag scales . Total out the door was $326.91 and $37.91 was the cost of shipping from England, not bad. The cross feed is a 1um, carriage is a 5 um. I'm going yo use Yuries interface with my Lenova M10 plus pad.
If you have never checked out the M DRO web site take a look. All kinds of goodies and shipping is reasonable. Their slim model is smaller than Electronica or other brands and made In house in England. I may try to do a y tube video of my installation.
Mike
I worked some more on the clutch pack. I'm still waiting for a Clausing parts delivery and then it will be installed.
Whoever worked on this before was not very mechanical inclined. They cut the square key that locates the clutch pack on the shaft. There Is a snap ring that spits the keyway in half, half of the key goes into the clutch pack and half goes into the clutch actuator. So I purchased a new key and just have to camfer it. The Snap ring if centered on the keyway does not touch the key. Imagine that.
