- Mar 26, 2018
- 8,413
Please explain. I am not familiar with this issue.Judging by requests for spares,the feed gears would be something I would give close attention to......
I know someone who can make gears though
I was hoping to power the lathe with the same VFD I had planned for the mill.
The mill is a 3HP and the lathe is 7.5.
Oh well, i'm thrilled to have the Clausing!! I'll work something out.
The 92 year old machinist I bought the B&S Micromaster from had a Rotary Phase Converter that powered his whole shop.
VFDs go up to really high power ratings, over 100 hp, I assume. But they are $$$$$. In a home shop an RPC usually starts to take over when more than about two 3 phase machines are present, or if one machine is over about 5 hp. No real knowledge here, just what I have gleaned from discussions. Decisions like these also morph with changes in technology and with what else becomes available, and at what cost.The very valid point here is to plan ahead. I had no idea that I wanted or needed a real lathe once I ordered up my RPC & sized it perfectly for the 1 mill. Now, I'm realizing that I have a choice as I move forward: Get a lathe that also uses a 5HP or less motor or expect to get a whole new RPC for a 5+HP lathe.
At what HP rating do the VFDs max out at anyway?
On a lathe of that size and power, I would be looking at a used Hardinge Sjogren collet chuck set, takes 5C, 2J, 3J or 22J collets, depending on the model, or maybe a bigger than 5C lever collet closer. I sold a 2J one for a friend some years ago. Very nice collet chuck! A lever collet closer would be better for production work. Again, maybe larger than 5C. What size is the spindle bore?How to acquire a 5C D1-6 collet chuck and quick release fixture?
