Clausing 4904 just purchased. newb question
ExoFatty
Oct 29, 2021
Location
irwindale
Hi guys I just purchased a used clasing 4904 lathe to to basic stuff. I'm pretty new to lathes and took a course in 2006 on basic lathe work and just used all the equipment at school
my main question is. is there a better tool holder upgrade to purchase? or multiple tool holders? I want to use a parting tool and dont have the proper holder. Aldo replacing the exhishisting holder would be nice. Any variations of quality options would be greatly appreciated
the tailstock is stuck and saw how someone's keyway was broken. Well , I'm pretty new and I screwed it out as much as possible and now it wont go back in. when i was turning it was real tough. Anyome that does quality machine work repair in southern cali someone recomends?
as well as my tailstock being hard to turn, the angle cutter wheel is hard to spin as well. everything else spins good. left right and foward and back handles are good
thanks in advance!
Some pics would help to see what tool holder you have now? I think most people would recommend an Aloris type Quick Change Tool Holder. That would be my recommendation. You don't have to go name brand on Quick Change holder and Quick Change tool holders. Aloris is just the style. I am sure someone with a similar size Clausing can let you know if BXA is the right size of QCTP for you. Good luck.
that's my current setup. right now im just want to cut cylindrical spacers to get me into shape. facing and turning down the round stock is fine but i want to use the parting tool.
I will take a 2nd look at the tailstock
The Clausing 49xx is a 10" swing machine. We only have two slightly different 4900 Series manuals and no Clausing catalogs so I was unable to determine what the 04 means. But I would recommend that you opt for the AXA series of QCTP. The AXA is nominally made for 3/8" square tooling and can hold 1/2" barely. There seems to be a fairly large price increase for the QCTP, the tool holders and the tooling between the AXA and the BXA, larger than from BXA to CXA.
One general fallacy not usually appreciated until after the initial purchase is that if you only buy one of the "kits" that usually comes with the tool post and 4 different holders, you almost are no better off than with the Lantern style holder if you need to use more than one cutter. I think that I have over a dozen of the common turning and facing holders with different types of cutters already in them and with the vertical positioners already zeroed in.
There are two styles of tool posts, wedge and piston. Mine is a Yuasa piston type b0ught 40 years ago. But Yuasa no longer makes QCTP's and most of the Chinese made ones have smaller or much smaller pistons. So I and most other people generally recommend that you buy the wedge type. Fortunately you only need one tool post. Tne actual cutter holders are all the same, regardless of which TP you have. As far as brands go, you will have to ask others. As I haven't bought a TP in 40 years.
thanks, the seller did give me a few pieces that were 0.500" and i was very close where i did not want to fit by hand. I'm petty new and will see if my friends nearby can help me out. i would love to throw on different tools to help my lathe game.
appreciate all the comments and suggestions
Congratulations on the new lathe. My first recommendation would be to STOP cranking on handles that are difficult to turn ! The tail stock and compound slide should turn with little effort. You can cause damage by forcing these things. I would disassemble these components, clean and adjust/repair as necessary before going any further. These are pretty basic mechanical mechanisms and are generally not difficult to disassemble.
Just my .02 cents.
Ted
Thanks for the response. Looking at it there are only a few pieces. Either the keyway is jammed and/or the dial comes off?
I need to correct an earlier post of mine in which I described a tailstpck ram lock as having a pair of vertical cylinders drawn against and locking the ram by turning a handle mounted on top of the tailstock. Although that is one way to do it, on the Clausing 4900 Series. the two cylinders are horizontal and the locking lever is on the rear of the tailstock.
Top Bottom
