- Nov 16, 2012
- 5,596
I'm going to toss something out here that may sound unusual. I'm also embedding some tips along the way.
1) TIP: First, rig-up a balancing mechanism (I can provide demonstrations) and find the heavy side of both the backplate and chuck. For the chuck, mount a bar in the jaws and set it on bearings. When you re-assemble things, put the heavy sides opposite of eachother and the "average" balance will be closer to neutral.
2) I don't put shoulders on my 3 jaw chuck backplates that are designed to retain the chuck. In other words, I push the diameter of the shoulder back about 1/16" so it is not a tight fit with the inside collar of the chuck. I make sure the backplate is flat (with a face cut) on the shoulder area. I take the jaws out of the chuck and I surface grind the back of the chuck so it's flat. Finally, lightly attach the chuck with the bolts to the backplate and lathe then, mount a proof rod in the jaws and tap the chuck body until it's centered using a DI about 1" from the jaws. Now tighten the bolts. -Done. With the bolts properly tightened to roughly 20ftlbs torque, that chuck will not move and if it does, it's doing you a favor by giving way before your bearings and spindle take a pounding.
3) With a proof rod in the jaws, move the DI out about 4" from the jaws. If you're seeing a large difference (greater than 0.004"), then the jaws need to be tested and possibly adjusted.
4) Once a chuck is mounted and aligned nicely, it's always a pleasure to work with a balanced chuck. I always take the time to do it. Read-up on the acceptable procedures before you try lest you make a doorstop out of your chuck.
Ray
Ray
