- Apr 30, 2015
- 11,376
Bruce your dad was pretty generous- I think even two diameters is pushin' it
Depends on the size of the chuck tho and the stock
Why are 2-3 flutes preferred for slots and does it apply to steel and aluminum? I hadn't thought about roughing endmills. Thanks. What advantages can HSS and cobalt have over carbide?So, practically speaking, I would buy end mills in 1/4" increments. Buy centercutting when possible, sharp corner radius unless a radius is called out and have 2 or 3 flute end mills for pockets and slots and 4-6 flute end mills for profiling. Buy high helix 3 flute end mills for aluminum if you can afford them and please, please buy roughing end mills. Get coarse pitch roughers for slotting and fine pitch for profiling - they run 20% faster on both feeds and speeds and will help your finishing end mills last much longer. Buy HSS or cobalt for most jobs and get carbide for deeper cuts or when you have to hold really tight tolerances.
Thanks for the insight. Do you have any go to brands for HSS?If I could have just one endmill it would be a HSS 3/8", 2-flute, double ended endmill made in USA with about 1" flutes
Of all the ones I have I reach for that one the most
-M
That makes sense. I would have guessed more flutes would clear the chips better. Thanks for the info.Cutting clean slots is difficult because the chips tend to bind up in the slot and give a rough, choppy finish. So fewer flutes works better, gives the chips someplace to go
Good question about USA endmills. I think Cleveland and Niagara are still making them here. Brubaker, Morse, SGS are some others. I'd do a search
Most of mine are old brands that are out of business now like Putnam and Do-all, I purchased an estate sale lot with new and nearly new ones but they are quite old. They don't have a "use by" date tho
