- Dec 18, 2019
- 6,538
Speaking only for myself, my lathe and tailstock are from LMS. The tailstock is quite high. It needs to be lowered. My horizontal offset is controlled by a differential screw tailstock adjuster that I made and documented. The horizontal offset has been trimmed practically to zero. My headstock has been adjusted to pretty low runout in the horizontal direction. The vertical tilt, while not great, is acceptable.
The OP got their lathe from an entity who may have assembled it from a bin of rejected parts. If it was me, I'd first try buying the tailstock assembly from LMS. It's likely to be high, as the factory makes them this way on purpose to accommodate wear. However, 0.125" high could mean that the tailstock is made totally wrong, or assembled wrong, or the tailstock is riding on top of the locking plate, instead of the ways.
