- Sep 6, 2016
- 113
Greetings all! First time here... not actually a machinist, but a knife maker.
I need to be able to cut brass (only) that's no thicker than 1/4", 1/8th " wide slot, 1/2 to 3/4" long. This is for making finger guards on knives where the blade goes into the handle. Traditionally, I have done this by making a hole and then sitting with pin files for half a day. OUCH!
I have just seen a very affordable mill ($190) on the interwebz. Now, I realize that this is a cheap, small, underpowered machine.
It only needs to be able to do the task I described above. I don't even expect it to be able to cut the 1/4" deep slot in one pass. 8 to 10 passes would have to be better/faster by far, than the better part of a day spent with files.
Headstock speed is only 2000 rpm. Passes would (I think) be shallow without much force.
I am looking for your opines on this machine.
http://www.ebay.com/itm/Metal-Mini-Milling-Machine-Micro-DIY-Woodworking-Power-Tool-for-Student-Hobby-/251811966308?hash=item3aa129ad64:g:U4MAAOSw3xJVXEAc
Thoughts pro or con are highly appreciated!
Many thanks for your time!
Ex
Ex
