- Jan 30, 2013
- 23
I'm putting back together my 11" logan lathe after I disassembled the entire thing. However when I put back my change gears I noticed that the alignment between the change gears and the QCGB gear is slightly off. Also, the between the change gear and the reverse gear assembly.
I attached some pictures of my current assembly with everything tightened down. You'll see in the pictures how off the gears are to each other. Is it fine the way I have it or did I mess something up on the installation?
