- Apr 14, 2014
- 3,169
I currently have several sizes over 1". I believe the largest one is 2" in diameter. The truth be known, I don't even remember what job they were originally purchased for. It really doesn't matter, I've used them on many jobs since then.There's the head-slap I needed. I didn't even think to look for XL sized countersinks. I just assumed they stopped at around an inch or so. I will look at these more. Thanks!
If you're considering countersinks I would stick with brands like Keo and MA Ford. All my stand alone countersinks, 45* 82*, 90* and 100* are all these brands. Personally I prefer the "uniflute" design to the others available. They don't chatter, even when used in a hand drill or drill press. They can also be sharpened to any profile you choose using a surface grinder and an MA Ford sharpening jig. The jig is somewhat expensive if purchased new, but far less expensive when available on eBay.
Here's are some pictures of my older jig. The new ones come in a plastic box rather than the wooden one.
I do have some smaller size Magnavon's that were originally made for aircraft work. I do like them because of the "microstop" feature on the cage. Here's an example of some Magnavon cages with the microstop
Lot of 4 used Magnavon ATI Microstop Countersink Cages aircraft aerospace tool | eBay
These were heavily used in the aircraft industry, and readily available on eBay for quite some time. They're fewer available these days, and the actual countersinks are getting somewhat harder to find
