Chambering short barrels in the headstock
Cutting the slots for bolt handles. It’s a slow process. Sure glad I am not making this out of steel!
It’s 5” OD and 2” ID x 7” long. With the backplate it’s about 8” overall.
I noticed that you chamfered that transition.
That fixture looks great! Awesome work.
Annular cutters and that slot is cut in 5 minutes.
Got the machining all done. I ended up putting some extra hole sets in while it was all set up in the mill. Easier now than trying to set it up again later if I needed additional positions.
Now I need to make some brass tips for the screws
Did you use a backplate, or mound studs directly to your fixture?
I used the same backplate as you did from Grizzly.
I went with three bolts that are 3/8x16, and they reach 1.5” into the aluminum. Spider holes are all 3/8 x 24.
Since the fixture is @1.5” thick, with 1.5” grub screws there will be no screw head ever protruding from the fixture just as an added safety measure.
