- Apr 23, 2018
- 6,582
You can make your own spotting drills for free. You can re-point a broken drill to the angle you want for spotting regardless of helix angle. You can thin the web and use a 2-angle grind or other little tricks to get the result you want. Since chip removal isn't a problem, I just grind D-bits in a conical profile with a good clearance cut past the cutting edge. They can also be ground to match fastener heads and run as a countersink. If the subject interests you, read Harold Hall's tool grinding book that is included in our site's free library. He does more to explain drills in four pages than you'll find in some of the big references.
