Centec2 horizontal mill refurb
Fortis64
Active Member
Active Member
Dec 8, 2016
37
Likes
24
#1
Hi there , for the past year or so I've been trying to get this mill ,it was lying outside next to my work place (broke my heart seeing there) I tried the owner umpteen time to buy it until finally last week we started negotiations . At first i though he'd be wanting a fortune for it ,but luckily for me he hadn't done his research . They just thought it was an old keyway cutter lol....
Anyways it's now sitting in my shed in bits . First thing I ordered where Timken spindle bearings (they cost more than the mill itself !!! ) So I've now stripped all the old paint and cleaned all the nasty cutting oil in readiness for the filler undercoat to be applied . This thing is almost in unused condition both leadscrews are totally unworn condition ,the ways/dovetails still have the milling and grinding marks . The on part that shows it's age is the traverse half nut . Pictures to follow ... If anyone on here has any knowledge/owns one of these amazing little mills I'd greatly appreciate any input/advice .
Sean
Images of Centec 2
34_40
Dazed and Confused
Active Member
Nov 2, 2013
646
Likes
139
#2
I hadn't seen one before. It looks quite stout.
Good on you for saving it.. Thanks for the pics too, Can't wait to see the refurb completed.
Martin W
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Mar 26, 2014
277
Likes
167
#4
Sean,
That is a nice looking mill.
Is there a gear reduction on the table feed? With that gear it looks like the table would travel 3" with one crank of the handle?
Keep the pictures coming as you restore it, as it looks great.
Cheers
Martin
Fortis64
Active Member
Active Member
Dec 8, 2016
37
Likes
24
#5
Hi Martin ,there two lead screws on the table and there's a fast traverse Handle that fits on the tapered small shaft on front left of the bed .Will try and remember to take photos as I progress ....:acne:
Thanks
Sean :)
Sean,
Cheers
Martin
Bob Korves
Jul 2, 2014
4,024
Likes
4,171
#6
Nice mill! Interesting square thread on the lead screw. I guess on some level the seller was correct -- it is a keyway cutter!
Fortis64
Active Member
Active Member
Dec 8, 2016
37
Likes
24
#7
A keyway can be cut on it for sure ,just one of the many operations it's capable of .
Sean
34_40
Dazed and Confused
Active Member
Nov 2, 2013
646
Likes
139
#9
Man that is coming out nice! Looks like a great machine to operate as well. Keep up the good work, cannot wait to see it making chips.
Silverbullet
Active Member
Active Member
May 4, 2015
2,340
Likes
1,055
#10
Nice mill , no wonder you had to save it. Good for you , beefy looking little baby . Lucky bugger , that's big you suck . Looks like the grease and grime protected it well.
RandyM
Lead Man (Mod)
Staff member
Apr 12, 2011
1,799
Likes
1,342
#12
Very nice!
Keep the updates coming.
Fortis64
Active Member
Active Member
Dec 8, 2016
37
Likes
24
#14
I've since fitted a motor and the counter drive pulley's , but unfortunately through my total lack of knowledge I've found out the motor I purchased second hand is a 3 phase that's been wired to run as a single phase !!!!!! So I've now had to buy an inverter for it . I've also made a new handle for lifting and lowering the knew . First internal taper I've turned on the Fortis lathe turned out really nice . Also I had to move the motor over 2" and make two mounting plates drilled and tapped .
20170728_063720.jpg 20170726_205157.jpg 20170728_063611.jpg 20170728_063553.jpg 20170728_063720.jpg
tweinke
Mar 24, 2014
657
Likes
355
#15
Too bad on the motor but there could be a bright side if you use a VFD you will have more speed control!
Fortis64
Active Member
Active Member
Dec 8, 2016
37
Likes
24
#18
Fortis64,
This may be a late post but someone should have sent this link to you for additional info on this machine, The site has info on 2 or 3 centec
<http://www.lathes.co.uk/centec/index.html> Tont also has the manual and other info and he's in the UK.
Regards
dgehricke
Thanks dgehricke,
I've been on this site ,it tends to lean more on the later models .
I now have the vfd up and running and it works a treat ,just have to work out how to fit a variable speed control rather than having to alter the settings every time .
Sean
Container Above bottom breadcrumb
