Cast Iron High Temp Bearing Housing
Doug Gray
H-M Supporter - Commercial Member
Oct 28, 2020
528
I got a paying gig to make up a pair of cast iron High Temp Bearing Housings ( the yellow parts). A bronze bearing rides on a hardened auger shaft, and this housing holds the brouze bearing onto the end of the auger housing. This end of the auger lives in a very hot, dusty, abrasive environment.
Yesterday evening I got my stock cut down to size and decked the top side were the two halves will bolt together. I dilled the 3/4" diameter holes on my mill/drill. Tonight I notched the corners. I used my Milwaukee port-a-band with a Swag Ind. table. I drilled a 3/8" hole in the corner and sawed up to it.
Here I am using my daily 3" Macjhinist Clamp (from one of my kits) to extend the Incra Miter gauge.
3" and 4" Machinist clamp used to create a fence on the Swag Table.
Corners notched.
Setting up for rota-broaching the centre hole.
After the rata-broach the two halves will go onto a lathe faceplate for further boring. (fingers crossed) stay tuned.
Did you know working with cast iron + wearing crocs = Crocpox?
Nice clamps in pictures 3&4. Who makes those?.
Also you might want to see a podiatrist about that condition l.
Cutting oil is my blood.
Do you need to provide a hole for a GITS oiler to get oil to the bronze bushings? And how about a cover plate (if the environ is abrasive and dirty)?
Bearing or bushing ?? Just changed out bearings on a large furnace with a pair of self aligning bearings . 8 hr job . Should have been 2 hrs but the motor frame was different and had to drill all new holes and shim out for the couplings .
Nice work. I wonder how the bronze is going to survive in those operating conditions.
I misspoke The bearing is actually "Cast Hard Iron" it runs dry, the heat would quickly evaporate any grease or oil.
The auger feeds 5/8" down aggregate into a rotary dryer similar to this.
thats cool! I've never heard of that before!
The bearing I showed is called a hanger bearing, normally it is hung mid point in a long auger to support the screw/prevent whipping. They come in a variety of materials. Martin Sprocket and Gear still sells wooded ones.
Is there a reason the split line of the bearing is vertical? I would think having the load zone out of the split area would give it more life, and would be easier to install in that orientation.
