- Jul 20, 2014
- 1,386
I'm thinking of switching the base of my 3 x 3" finger plate project from O1 tool steel to Cast Iron or some other, harder steel. I may heat treat some other steel, but I'm finding that O1 is very hard on cutters, blades, files, etc... You really need a good, tight mill to get close to accurate dimensions with O1. I'm considering the use of cast iron if I can find a good source. Has anyone used the CI from McMaster Carr? and, what are some good tips when it comes to machining CI? Carbide, cobalt or HSS? Un coated? I would need to square the blocks on all sides, plus a V groove, drill/tap and possibly bore a counter-bored hole. Do you machine CI dry? SFM recommendations? Can a flycutter be used to square flat the two large sides?
