For some reason, every time I lay out a bolt pattern on my small import mill at least one set of holes is off by .008". The holes adjacent to them are off by .002" and measuring the remaining 4 possibilities on a 6 hole pattern are spot on.
I am building a spur gear differential for a robot project, are these minor issues going to adversely affect the spur gear mesh?
I did 3 test patterns in 6061 being very careful to always turn the hand wheels clockwise (passing the mark then zeroing in on it to relieve backlash) - spot drilled for center, drilled undersize in one shot, then reamed to a precision .250" hole.
Any suggestions or feedback on my method, or should I just run it?
More details for anyone interested:
12 tooth 24 pitch pinion for each axle
12 tooth idler gear that basically connects the two sides
.50" centers on everything
6 holes, 4 of which will carry idlers, the remaining two just for holding the structure together
.250" rods for the idlers to ride on
idlers made of delrin
pinions machined into the axle shafts in 6061
side plates will have a ledge that rides in some larger bearings
the axles/pinions will ride on a thin delrin sleeve inside the side plates
one side plate will have 60 external gear teeth to mesh with the motor pinion (this is why i`m sweating it, lots of gear teeth to cut into it after doing the major work above)
Edited to add: I was thinking since i`m only using 4 of the 6 holes for idler gears I could pick the best four and eliminate a lot of the error. But still, i`d like to know what i`m doing wrong!
