- May 4, 2019
- 792
If the brass is hard to turn it may be of adequate strength. I would guess either phosphor bronze or manganese bronze. Both materials look like brass.
I guess the old one made from kind of steel broke at the 7/16" side.If the brass is hard to turn it may be of adequate strength. I would guess either phosphor bronze or manganese bronze. Both materials look like brass.
I think weak point of part is where 7/16 dia meets shoulder . It would be stronger if there was a radius in that corner. I would put a .03 radius on turning tool and try to get good finish there.I guess the old one made from kind of steel broke at the 7/16" side.
Could have been metal fatigue after 100+ years.
The brass would look cool!!
I stole this from the web >>>>>
Steel, aluminum and brass sheet metal are all relatively strong and offer a high level of protection against corrosion. Steel, however, is the strongest, whereas aluminum is the lightest. Brass, on the other hand, is the most conductive of these three metals
13/16-14 PD is .7661Did you know back in the early 20th century, 13/16 14TPI was common?
Not anymore. I assumed it was 16 until I verified it to find the 14 fit perfectly.
In fact, I couldn't find 13/16 on most of the charts online. They skip right by it. There was a 13/16 X 20 UNF
Dang.
I used thread wires on the old part. I'll cut the threads to the same depth and hope it fits.
Right, but I have to add the diameter of the wires. Did I miss something?13/16-14 PD is .7661
I can still work that radius in.I think weak point of part is where 7/16 dia meets shoulder . It would be stronger if there was a radius in that corner. I would put a .03 radius on turning tool and try to get good finish there.
Jimsehr
Well, the original parts were made from low carbon steel so I guess 12L14 is OK. The owner wants it in steel.Gonna look great! Is corrosion an issue for these parts?
R
