- Mar 8, 2015
- 311
I was doing some maintenance on my 11" Logan lathe. Model 957, manufactured about 1952. I removed the plug on the front of the carriage which I assume is where you check the level of the lubricant. I probed around with a piece of wire-tie and could not find any trace of oil. So... what kind of oil? Do I just add oil thru this hole or is there an easier way. I'm including a picture. The screw driver points to the plug.
