- Oct 31, 2016
- 2,649
Instead of putting this in my small ring mauser thread I thought it best to do a separate thread for the carcano. The Japanese carcano type I (pronounced "eye") uses a mauser style trigger guard with a double stacked magazine like the large and small ring mausers. I like the looks of this way better than the single stack carcano trigger guard that you have to use the carcano clips with. I had been planning to modify a mauser trigger guard to fit the carcano receiver because I had never seen a type I trigger guard for sale.. I saw some posts online where people had done this. It involved cutting the mauser trigger guard apart and welding it back together to fit the screw spacing of the carcano receiver. And machining the receiver to fit the tigger guard. Then out of the blue 3 carcano type I trigger guards showed up on Ebay. The seller cut the their asking price by 10% and I bought one. Even with the type I trigger guard you still have to machine the bottom of the receiver to fit.
I have to go from this.
To this
The question I have are how do I hold the receiver on the mill's table? And how do I set it up so that the bottom is not tilted to one side? The top of the receiver does have a short section that appears to be flat where the bolt handle passes through the receiver. The magazine slot appears to have vertical sides and flat across the bottom of the slot. Other than the magazine slot there are only two holes through the receiver for the trigger. One appears to be 1/4" wide and the other might fit a 10-24 screw. To complicate matters the flat on the top of the receiver is lower than barrel end of the receiver.
Suggestions please
To this
Suggestions please
