- Mar 1, 2014
- 16
I'm looking for input on manufactures of counterbore drills or milling cutter. I need to make 3/8" counterbore in aluminum with no pilot hole, done in one pass with 60 degree countersink on a milling machine.
I think something like this is what you are looking for.
http://www.use-enco.com/CGI/INSRIT?PARTPG=INLMKD&PMPXNO=28075211&PMAKA=337-3444
EDIT: If you are trying to do a flat bottom counterbore with a 60* chamfer at the top, then you may have to have a tool made, I don't think I have ever see a stock one like that.
something like this sounds in order there are also counterbore drill combo attachments, but all the ones I have seen seem to be designed for wood in that case.Yes that's what I wanted to do. Drill or mill the bolt hole, counterbore and the countersink in one pass with one tool.
I do most of my chamfering by hand as well. I don't imagine there is much demand to make such a tool.I found this, but you would still have to do the chamfer in a second operation. http://www.mscdirect.com/product/details/56443971
Many times I do the drill/counterbore on the mill then do the chamfer on the drill press or with a hand drill
