- Sep 10, 2013
- 562
Hi All
Happy birthday to America.
:happybirthday2:
I have a new Bison 8" fixed jaw chuck I have just mounted, and I can't get it to cut a test pieces with out the outside ring from being .004 smaller than the ring up next to the chuck. The chuck has about .007 run out 2 out from the jaws.
I turned the back plate to size and faced the back plate. I checked the back plate for run out and the face for wobble but it did the .0001 Starret DTI hardly moved. I turned the spigot so it is a snug fit with a little pressure and used Transfer screws to get the mount holes marked and drilled them on my mill. The mount SCHC screws fit with no binding. I have checked every thing I could think of. The spindle only has about .0001 run out and no front to back looseness.The preload on the spindle is set to factory specs. I have checked the level on the lathe with my Starret master level and it is with .0005 from head stock to tail stock end cross wise and .0012 length wise. I debured the Bison jaws cleaned and lubed the scroll. I'm just kind of at a loss now. Any ideas??? I loosened and tied to see if I could tweak the head stock but it is fixed because of the V rail. I would like to get this figured out so my son can help with the work, I can't lift any thing for another two weeks so while he is hear, free labor :lmao:. If I can't figure it out then it will have to wait a few weeks longer. Oh it has the same run out and run out both sets of jaws?
Thanks
CH
:happybirthday2:
Thanks
CH
