Man, that is a nice looking machine!! I have one on the way (well I hope, it has gotten delayed from China once already) and I can't wait!! I got the belt drive and 3hp VFD on it. Looking at your machine I am dying here.
So, you have had your 12z for a year or two now right? How do you like it? Are you glad you bought it? Any recommendations/guidance you would give a new (or about to be) owner of one of these bad boys?
Actually, I do like it. For what it is, it's quite the little work horse. Let me explain that. As some here will tell you, I have bought quite a number of machines in almost three years because my desires kept changing the more I got back into this hobby. When I ran across the 12z I was looking for the biggest machine that I could man-handle by myself in the garage and that didn't require a fork-lift to deliver (the PM935TV wasn't available at that time). This machine was the first one that I bought that actually exceeds my requirements for work envelope. I do mostly pistolsmithing, some rifle work, and other small projects. I will use a 1/2" or 5/8" rougher when making the bigger stuff (my bigger stuff) like fixturing, tools, and whatnot, but most of the time I use 1/8", 1/4", and the occasional 3/8" size cutters for the work I do. My smaller PM25 uses these cutters as well, and performs admirably for it's size, but given the same task, the 12z just purrs along and doesn't get ruffled at all. Sometimes I wonder if it even know it's cutting anything with the smaller cutters. Gunsmithing isn't hard on machines, but it does require accuracy. And the smaller workloads I put on this mill will have it lasting a very long time. You can push this mill harder with 1" endmills and 3 or 4" shell mills, but the harder you do, the shorter the lifespan will be and I would argue that if you need to run cutters that big, you bought the wrong machine. My reasoning for buying this machine having already bought a PM25 was primarily to get the larger work envelope, not for using larger tooling. While the 12z easily handles tasks the little guy struggles a bit with, that was just icing on the cake for me. I will admit having a 2.5" face mill glide over a 20" long piece of Fortal aluminum at a 10 thou DOC finishing cut does put a smile on my face. For some here, that's nothing, but for me it's been a long time since I've had that capability.
So, having said all that...
First and foremost, this is a Chinese machine. Some things will work great out of the crate, some things will need tweaking depending upon your expectations and desires. When I got mine, I went through and pulled all of the gibs and checked them for flatness, burrs, and whatnot, then stoned them and did some homemade 'flaking' on the bearing/sliding side of the gib to assist in oil retention. Then I had to address the table in that it's top surface is ground (and very flat) but the edges were razor sharp and the surface a bit rough. The factory doesn't bevel the slot edges, so be careful, they are very sharp. I basically draw-filed and stoned the edges and ran a small file on the underside edges to remove burs so my t-nuts slide smoothly. And I stoned the table top to smooth it out a bit. None of that was much in the way of work, but I figured it would make the overall use experience more enjoyable.
Then I decided to put on the one-shot oiling system from CO. To do that you have to pull the table and saddle as the saddle has to be drilled, tapped, and the oil galleys on the ways have to be either machined in or done by hand with a dremel and carbide burr. So with the table and saddle off I decided to examine, measure, debur, stone, etc., the mating surfaces of the saddle and table. I followed CO's instructions for installing the oiling system as I had no idea of what I was doing back then. Now, after using and thinking about this some more, I would have done it differently, and actually end up with a simpler, more efficient system (I may do that in the future). I didn't do the oiling system mods to the head/column interface piece as I was impatient to get the machine back together and using it. So I keep a oiler handy and squirt the column ways down before I use the machine. I may eventually finish the job, but it's not on the radar right now.
There's more, but somewhere in this sub-forum is a thread or two I started when I received the machine and kinda followed through my setup and initial mods. If you can find them they may help when you get started on your machine. And, you can start a setup thread of your own and I'll help when/if you want it.
I don't want to lower your expectations any, but I hope you're not expecting a perfect machine to show up that doesn't have any loose screws, slightly mis-aligned front plate (mine was canted a bit, but nothing a file couldn't fix), or other fit/finish stuff. It IS a chinese machine after all. But...the major pieces fit together quite well and perform as expected for a machine in this price range.
I hope you enjoy your new mill!
