As in the subject, suppose I have a high speed plain bearing spindle (2700rpm - that is high speed for oil filled plain bearing). It has runout over double of what it should be, but I learned to compensate for it and I can get good finishes on the machine (by varying speeds and feeds). Can my spindle get damaged by running like this for an extended amount of time?
For those interested below are more details.
I made an unpleasant discovery of a pretty substantial runout (at least when cold) on my plain bearing surface grinder spindle (0.04mm/1.5 thou, the limit for this machine is 0.01mm/4 tenths). Based on a finish I get on a single pass with a well balanced and dressed wheel I suspect somewhere around 0.02mm/8 tenths of runout when warm. I'll measure it properly when I have 2 hours to warm it up properly (that's the warmup time according to the manual). I can get good finishes by running multiple passes at varying feed stroke, table speeds and making light cuts. I would like to improve it if possible, but I think the plain bearing may already be on its full adjustment. So without some work I may not be able to remove that runout.
The spindle runs at 2700rpm.it uses a tapered plain bronze bearing on the front and two roller bearings in the back. It has a nut to adjust bearing clearance. The clearance now is similar to runout. I can push the spindle up and down 1.5 thou when cold. The adjusting nut feels like it's bottoming out. I can force it further by slamming my hand on a wrench (no cheater bars, just a 9~10 in long adjustable pin wrench), but I reverted to the previous setting in worry I'll distort the bearing by forcing it.
When I did my lathe's plain bearing I could make the spindle immovable before the nut got hard to turn.
So, if anyone knows, first, am I damaging my spindle further by running it with too much clearance. And second, am I correct in assuming the adjustment nut should be able to seize the spindle well before it requires force to turn?
