- Apr 30, 2015
- 11,328
First of all, wire colors are meaningless except for electrical codes which specify specific colors for residential wiring. Wires are colored just for identification purposes. The electricity itself doesn't care, if that's what you were asking
Secondly, the switch you show in post 20 is a different animal. It uses contact pairs, which means jumper wires need to be added
in order to be useful for motor reversing. I would say also those import switches probably won't last as long as the Furnas style units, but they are cheaper.
Third, you won't need a neutral for this, only the two hots and ground. You only need neutral for 120 volt circuits.
I can do a sketch for using the baomain switch- I shall return
