- Nov 25, 2015
- 8,322
That makes no sense to me. I guess I am slow, but how does that apply here?It's like using all of the pig but the squeal.
That was my thought, you wouldn't glue up a board, instead just rip it to 6" wide without the added strip. Only thing I can think is it was rejected from a wider glue up, like one of those 2' wide or more, and rather than re-glue it they just ripped it into 8" pieces.it's fine and won't be painted, just can't believe they went through the time and effort ($$$$) to glue up a board. Seems like a waste of time.. just sell it as a narrower board. To me it just makes no sense.
It's using every scrap of usable wood to produce a sellable product; I assume that most of the work done to produce the end product is done with exceeding little human effort or direction.That makes no sense to me. I guess I am slow, but how does that apply here?
Also, anyone who has tried to hand-pick lumber at HD has probably gotten in trouble for transferring an entire bundle of warped and knotted firewood into the aisle...Clear pine, aka select or #1; just means that it is free from knots pr other defects. Wider clear pine boards are often edge glued nowadays. They're cutting smaller trees and its harder to get wider boards. I'd consider myself fortunate if there isn't bark on both edges.
When I go shopping for lumber, I always hand pick mine. There is some really obnoxious lumber masquerading as select out there.
I also don't buy my lumber at HD. Anyone who refers to their lumber as "white wood" doesn't need my business.
GsT
I'm aware, but the lumber yard where I used to go started treating my like crap. Seems they too only want to deal with contractors, and before I stopped going, I could often get no one to write me up. They would ignore me and just keep having conversations with the contractors, and even if the contractor left, acted like I wasn't there. I got the picture after a few times. I was sorry to lose them as a supplier. But I'm not going to get on my hands and knees to beg them to let me buy from them. 22 years and that's how I was treated ..Clear pine, aka select or #1; just means that it is free from knots pr other defects. Wider clear pine boards are often edge glued nowadays. They're cutting smaller trees and its harder to get wider boards. I'd consider myself fortunate if there isn't bark on both edges.
edit: BTW, premium is not a standard lumber grade. It is a marketing tool.
I've never actually been in trouble at HD, either. BUT, you can go through everything they've got without finding anything that could even aspire to mediocrity. Fortunately I don't do much with wood anymore, especially since moving to AZ, because the local-ish 'good wood palace' has prices that make titanium seem like a very reasonable alternative.Our regional big box DIY is Menards. They don't mind if you sort through the lumber. They do appreciate it if you don't at least make an attempt to straighten up when you're through.
