- Dec 20, 2012
- 9,422
In a few months, my wife and I are going to be buying our first house.
No matter how the shop turns out, CONGRATULATIONS on your first house!!!
And of course, the more space the better. If you can put up a 30 x 40 x 10' barn next to the house, all the better.
Too small.
Ok, how about 36x40. Too small.
40x40? Too small.
40x60? Maybe
In all seriousness, if you (Marcardoso) are going to build a shop, do NOT build it with an 8ft wall height. If you decide to work with wood at some point, 8ft ceilings suck. My last shop had 10' ceilings and that was good. Current one has 11ft ceilings. I would not go over 12ft though unless you have a specific need for that much height.
Floor treatment....
A couple of pictures when I was building my shop last year. It has a stain applied and then a clear sealer over the top. I like how it turned out. My previous shop had an epoxy coating with the flakes added to it and then sealed. I liked that too, but did not want it in my new shop due to cost, and it also does chip if you are not careful. The more flakes you add, the more grip it has generally speaking.
I stained the front entry of the house with a different product than my shop. I really liked it. (picture attached) Super easy to work with and non-caustic. Water based. The company was very helpful too. ---> Sim Stain <---
Some observations:Thanks everyone for all the suggestions so far! We are going to be moderately close to Detroit, so yards and lot sizes are not large. I'd probably have a hard time finding space for an outdoor shed/pole barn shop. A 3rd bay of a garage would be great too, but we saw none when we went house hunting last week. I was really hoping to end up ground floor, but I'm thinking that is less and less likely to happen.
I did move my 1000# lathe into a basement once, but it was not fun. I can certainly do it again. I would have liked to buy a knee mill, but that may not happen. For me, having a closed off shop where the cats don't sneak into, with better lighting and storage than my current setup would be awesome. As much time as I spend in the shop I don't make a large volume of parts, just whatever sounds fun to me, so it doesn't need to be the most production focused setup.
I do absolutely zero grinding right now and I intend to keep it that way. I'm actually not bad on a grinder, but it makes such a mess indoors that I stopped and found other ways to do what I want. That might change one day but not now.
I like the plywood on the walls suggestion. That would really make mounting stuff easy!
Any thoughts on treating a concrete floor? I'd rather not get it all oil stained
