- Apr 30, 2015
- 11,376
Tilt and nod are different things- nod is like when you nod your head and tilt would be like leaning your head to the left or right.
Then there's swivel which is like turning your head left or right keeping your eyes parallel with the horizon
Also, I believe the shortest Bridgie table is 32", I have seen a few on Ebay that short.
The longer tables can actually be bent if you can believe that, but not from having heavy things put on them. It happens from overtightening the t-slot bolts holding the vise over a period of time- it apparently warps the table. I have heard it can be corrected by peening the underside of the table, not an easy job though.
The variable speed heads are fine if they are in good shape when you buy it- if you find one, spend some time running it a different speeds and listen for bad noises and vibration.
Bridgeport isn't the only game in town, it's just the best known. Other good mills are Cincinnati, Index, Van Norman, and Gorton
