- Sep 28, 2013
- 4,309
lovely work, I keep meaning to make a better rest for my grinder too. I second the suggestion for a better wheel. If you can get 2 wheels a 30 to 60 grit for roughing/ shaping and a 100 grit for finishing will work well. I only have 1 grinding wheel on mine, so went with a 100 grit Norton wheel and it works very well. I can always use an angle grinder for shaping
Also, chisels are often ground using the end of the wheel, holding the chisel at the top. That gives a hollow grind that works well with chisels. Grinding on the side will give you a flat grind, which is stronger but you won't be able to get it as sharp.
