I have been wanting a sheet metal brake for quite some time , but they are expensive and won't handle anything very heavy. After searching off and on for a couple of years, I settled on the one designed and built by J. R. Williams. The only thing I would change is I want it to be a finger pan...
This is a project I've had in the works for a couple years. I didn't work on it on a daily basis, or even a monthly basis for that matter. It's been sort of a fill in thing for when I had a few extra minutes to spend in the shop. With the recent "social distancing" recommendation I felt it...
www.hobby-machinist.com
The original plans are in post #4. In this case the original machine was only 12" wide. My version in the pictures is scaled up to 36" wide.
