Guys if you had a choice, which one would you choose and why?Both would be lubricated with oil via splash as it works it way down the shaft to either bushing or roller.This shaft is power by belt driven 3hp motor so I guess there is alittle downward pressure which makes me think that needle rollers would be better.But going the roller route the sizes are limited but with the bushing I can bore it out to size.Guys over in the Clausing section is my story about oil seal,bearing if you want to find out what's behind this question.Thanks---kroll
Story behind the question http://www.hobby-machinist.com/threads/oil-seal-for-the-colchester.44154/
