- Nov 25, 2015
- 8,390
so I have some stainless foil.. it would work.
I assume you don't have it. But what I would do to get you by so you can redo a new bolt:
I would wrap the stud in tin foil. wrap it carefully using a tooth pick to tighten up the thread.
Then make a new stud.
if it doesn't work, consider loctite perm or bearing to hold the stud in, redo your stud, then heat the old stud and remove.
